Need custom stereo surround help - 1968 Chrysler newport
  • 1
Biggredd2069
CarAudio.com Newbie
I have a 1968 Chrysler Newport convertible that had the most pain in the a$$ stereo ever to remove. Had to cut the dash apart and I modified the opening to go from the original am only stereo to a modern stereo.  The problem is the dash is very uniquely shaped and I can't fit it in normal. The dash angles from the middle of the stereo back so the middle of the stereo is flush but the sides are exposed as the dash angles back. Secondly the dash angle back so the bottom of the stereo touches but the top is exposed.  If I try to angle the stereo to by flush it hits the hvac on the inside.  So I need to figure out some sort of faceplate surround that doesn't just have me showing exposed stereo sides.  It is a single din.
Also, it only has a red and orange wire going to the stereo and nothing else.  There was a strap bolted to the back that I'm guessing is the ground.  Since there wasn't a need for a constant on this old school radio I think I'll have to run my own constant power, Can possibly tap into that strap as the ground and then use the red as the car on/off, and the orange as illumination?  hope my thinking is right.
I have a 2006 Honda Odyssey with a 130amp factory alternator. I have done big 3 with ground to chassis and engine ground. I run a 2000watt RMS...
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
62
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
419
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
328
Biggredd2069
CarAudio.com Newbie
Biggredd2069
Biggredd2069
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
