Need Help With Amp Settings
  • 2
yroc434
Va
ok i have a CAB 1600.1 pushing (2) SA-12D4's wired down to 1 ohm! my amps settings are as follows:
Gain (goes from min-max)
LPF ( 40hz-180hz)
Subsonic (off-50hz)
Bass Boost Frequency (30hz-80hz)
Bass Boost (0db-12db)
now where are these settings best set to? i hear not to use the Bass Boost so i have that and the Bass Boost Frequency set to its lowest levels! Gain is currently set to about 25% from its lowest setting, now LPF & Subsonic im unsure! idk if this matters but my subs i have them in a custom 4ft^3 single chamber box tuned @32hz!
Any and All info will be greatly appreciated! thanks in advance!!!
I always start with: gain with a dmm to the output voltage I want with a 50z test tone, low pass around 80hz, and subsonic either completely off or something around enclosure tuning/4 then subtract that number for the subsonic. ie (32/4=8. 32-8=24hz). After this adjust accordingly based upon listening preferences and power being applied.
11
977
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
yroc434
yroc434
Va
yroc434
Decebal
    Jun 10, 2024
