Troubleshooting. Subs stopped working after amp tuning
  • 3
snconstine
I bought a belva 212 kit from sonicelectronix about 1.5 years ago and my friend wanted to make some adjustments to my set up. He was playing some music through and adjusted the LPF on the amp when out all of a sudden my subs just quit working. can anybody help me figure out what my problem is? I have no clue and have no experience with this sort of thing. I'm a beginner when it comes to subs, so if you need more information I'll do my best to help get it to you.
So the amp isn't powering on? Check your power, ground and remote wire at both ends on the cables
And I moved my underhood fuse block to be harder to see 🤣
28
3K
I'd probably start by making sure the connector at the back of the HU is tight.
Hi all, In the process of adding a sub and new speakers to my 5th gen RAM. In terms of what happened, I installed a 2x10 sub and it's running...
Yes you can if you have all the connectors in the rear of the stereo. There should be a bunch of rca connectors plugged in the back of it and if...
snconstine
snconstine
Owosso, MI
Massive spl
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
