Need ideas for LOUD dual 15" box....
  • 1
evilsaint
I have 2 15" Kicker CompVR's on the way, and I'm trying to decide what kind of box to build. Is there any way to keep the low bass loud *and* to keep the punchy bass hitting hard? I have no problem making a ported box, even though it would be huge, but from what I've heard, the low frequencies would sound awesome but the punchy bass (bass drum kicks, etc....) would suffer. Is this true? Any advice would be greatly appreciated.
what kinda volume would I be sacrificing with a decent sized sealed box as opposed to a larger, lower frequency ported box? For now, these are just for my listening pleasure, but later on I'd like to start competing.
One more question and then I'll shut up. I really do want to do a ported box, but from what I've read on Thiele/Small specs (spelling, i know), subs with a QTS (whatever that is) of .2-.4 are optimal for ported enclosures, but the 15" CompVR's have a QTS of .521. Would that matter all that much if the box was constructed properly? Also, for a sealed box, in your opinion, about how much space would each sub need to hit deep, but to also kick kinda hard? I suppose no matter what kind box I make for 'em they'll hit deep, just cause they're 15's, but it would really **** to listen to metal with no bass drum kicks coming from the trunk. My interiors now sound good, but they have about as much bass response as a quiet burp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif BTW, thanks for all the help.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
139
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
106
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
446
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
344
evilsaint
evilsaint
NW Chicago 'Burbs
evilsaint
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
