need opinions!!
noonbns
i need help making a decision i have a 760 watt two channel pioneer amp originally had it bridged and hooked up to a jl audio 10 in sub. my friend was in need of cash so i bought two twelve in visonik subs in a ported enclosed box i dont know if i should sell the 12s and keep the ten or sell the ten and keep the 12s only real problem with the twelves is the lack of trunk space so i dont know if they are worth keeping or not
any help would be greatly appreciated
Sell the Visoniks asap, they are a bottom of the barrel brand and will sound and perform like crap. Sell everything while you are at it and start over with better quality equipment. If you are adament about keeping anything you have, hold onto the amp, it does about 380w at 4 ohms bridged. Get a decent single woofer and put it in a custom made box and you will be well ahead of the other stuff you have in terms of sound quality and output.
i do love the JL very much it was given to me for free and i have had no problems with it thats why im so stuck on what to do plus the visoniks just take up way too much trunk space i purchased them for cheap without doing any research to help out a friend in need
yeah i mean i plan on upgrading in the future but as of right now my money is wrapped up in college but i was considering doing just that with the visoniks and using the money towards something like that. i just wasnt sure which of the two were better quality but everyone i have spoken to has said JL and to sell the Visonik so thats what im going to end up doing
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
137
192
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
144
501
noonbns
noonbns
ickesburg, pa
noonbns
audiobaun
    May 19, 2024
    May 19, 2024
