Need Opinions
  • 1
67Stang
I had two JBL GTO1014D's in two sealed boxes, but they couldn't handle the power from my amp. One of the cones came unglued, and on both the wires going to the voice coils burnt up. The amp is a Rockford R750-1D. Space is my real issue and I was wondering which subs I should get to replace these. Should I get 2 more 10's that can handle the power together or just get one sub that can handle the wattage and put it in a ported enclosure. Looking to spend around $100 a piece for the two. Primarily rap and dubstep bass.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
146
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
109
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
454
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
348
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
759
67Stang
67Stang
Middle Georgia
67Stang
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
