Need Questions Answered! Please
Ok guys, so i want to upgrade the amp in my car from the 2 SoundQubed 1200D strapped pushing about 2500wrms, to the Soundqubed 4500D.
I currently have a yellow top under the hood and a Kintetik HC2000-rev in the back. All 1/0 Gauge and big 3 upgraded.
Is it possible to run 2 Dual 2 ohm subs down to 1 ohm? Or since the Amp has dual speaker inputs would i just wire each sub alone to 1 ohm and plug into the amp?
Also in the 2000 toyota Corolla i have a stock alt, but everything else is upgraded. Battery under the hood, battery in back. All 1/0 AWG wiring. Big 3.
Basically what im asking is, if i use this setup with the 4500 watt amp what kind of power would i get out of the amp. Will it be louder then the 2 1200d strapped.
The car is fairly old and dont want to put a HO alternator in it or more batteries.
Will it be worth the buy?
No, you can wire to .5 or 2. What is your voltage drop like right now? That stock alt ain't gonna hang with a 4500 imo. What are you wired to now? 1 ohm strapped?
Sent from my SM-N920V using Tapatalk
Right now since they are strapped. Im running both 15s at 2ohm strapped power of 2600 watts.
Voltage drop isnt below 12v.
Nothing dims
Don't want multiple batteries but already have 2. yeah you make no sense.
It takes power to make power.
Get rid of the 4500 and go with the 2200.
Nothing dims
Strapped makes you have a lot of box rise. Meaning you are seeing pess than 1000 actual watta if you clamp it. Amps are fine, its just physics and the nature of subwoofers seeingpower in an enclosure along with strapping making it worse.
No alt, no play. If space and batteries is an issue, just sell all your batts and get a single lithium ion 40 ah battery under the hood.
Come on you must have made some money stealin those youtube vids.
Exactly!!!
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
142
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
106
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
446
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
345
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
752
SubwooferVideos
TX
Hertz Mafia
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
