need some advice....for powering my subs
  • 4
DeathGrind
Hello Everyone! I need some advice for powering my subs.
I just purchased a JL Audio CS210RG-W3v3-2.
Technical Specification
* Sensitivity: 85 dB
* RMS Power Range : 200 - 1000 Watts
* Peak Power Handling: 2000 Watts
* Impedance: 2 Ohm
* Low Frequency response: 25 Hz
* High Frequency Response: 250 Hz
* Diameter: 10 Inch
Link for JL Audio CS210RG-W3v3-2:
http://mobile.jlaudio.com/products_enclosures.php?menu=9&prod_id=424
I have a PPI A404 amp. Would this amp be enough to run the subs? I was looking through the PPI A404 manual and couldn't seem to find anything about running the amp at 2 ohms mono. I don't know very much about ohms and what not.
Link for PPI A404 manual:
http://www.directeddealers.com/manuals/og/precision_power/Precision_Power_Ax400_Owners_Manual.pdf
I have another PPI amp in my storage. Not sure what it is but I pretty sure it is a A600, A300 or a A204. I'll know what it is when I make a trip to my storage a few hundred miles away in the next few days. I do recall it being a 2 channel amp.
Anyway I have the PPI A404 sitting right next to me. Would this amp be enough to power my subs i just purchased?
I read that using the PPI A404 for subs is almost a waste, since it has such nice and clean mids and highs.
those subs are 500rms each and that amp is putting out 100rms @ 2 ohms so u need a way bigger amp. im not a fan of jl but i see that ur new to car audio so ill help u out, u need a amp thats putting out like 800-1000rms @ 2ohms to power these.
A good amp for you would be the Audioque 1200D (Located Here) or the new sundown audio SAE-1200D amplifier (located Here) Not quite enough power on the AQ, but I hear that the sundown is very underrated.
thanks for the info! I was looking for the suggested amps, and can't seem to find them.
Anyway, I don't really have much money to spend on an amp now. Most of my money went to the subs and my deck (Pioneer Premeire DEH610BT). I could maybe spend up to 150 dollars on an amp. I not picky at all, I just need something to power my subs with.
I assume since I just need to power my subs with a amp and since the subs are mono, I should be looking into a class D monoblock amp. No need to get a 2 channel amp for the subs i assume.
Thanks again for the help and advice.
Any one have any suggestion on a decent cheap 1000W RMS 2 ohm mono amp?
Hmmm this amp looks decent to me what do you guys think:
KENWOOD KAC-9104D ======
# Class D Monoblock Car Amplifier
# RMS Power Rating:
* 4 ohms: 500 watts x 1 chan.
* 2 ohms: 900 watts x 1 chan.
* 1 ohm: >900 watts x 1 chan.
# Max power output: 1800 watts x 1 chan.
# MOSFET power supply
# LED power indicator
# Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
# Stackable operation capable
# Phase inverter (0°,180°)
# Speaker-level inputs with signal sensing for automatic turn-on)
# Preamp RCA outputs
# Short circuit, DC offset, overload, and thermal protection circuitry
# Aluminum die cast heat sink
# Built-in cooling fan
# Gold-plated RCA level inputs
# Gold-plated screw terminals
# Variable low-pass filter (50-200 Hz, 24 dB/octave)
# CEA-2006 compliant amplifier
# Frequency response: 5-200 Hz
Well I ended up buying the KENWOOD KAC-9104D . Got it for around $130.00. It is rated at 2 ohms: 900 watts RMS x 1 chan. So that should be good enough to power my subs.
I found out that the other PPI amp i had was the PPI A300.2. Not sure what I'll use that for.
Well I ended up buying the KENWOOD KAC-9104D . Got it for around $130.00. It is rated at 2 ohms: 900 watts x 1 chan. So that should be good enough to power my subs.
that amp sould do fine on those subs, use the other amp for your front speakers
I have a PPI A404 and a PPI a300.2. I have read some good things about the PPI a404, so I think I will use that for my front and rear speakers. I'm having trouble finding some good 6.5" (front speakers) and 4" (rear speakers). The PPI A404 rates as the following:
Art Series Model: A404
Continuous Power Output:
(Front/Rear Output - Watts per Channel)
4 Ohms, 11-15 VDC, Stereo: 50 Watts
2 Ohms, 11-15 VDC, Stereo: 100 Watts
4 Ohms, 11-15 VDC, Bridged: 200 Watts
To bad I just ordered some infinity Reference 6022si. But they are only rated at 50W RMS, at 2 ohms i believe. I got some kenwood 4" speakers to but they are only 20 W RMS.
So anyway, any one have any suggestions on some good 6.5" and 4" speakers to run off my PPI A404.
Thanks
Nate
hey guys. One more question. The kenwood amp calls for a 4 gauge wiring kit, which I have already purchased. I was looking into getting a fused power block. Since I have already ordered a 4 gauge wiring kit, is it safe to use a power block to run a 4 gauge input wire, and then split it into 2 4 gauge outputs? Or could i just use a 4 gauge input wire and split it to 2 8 gauge wires? Or should I just buy some 1 gauge wire and split it to 2 4 gauge wires, I would rather not have to buy more wire.
Anyway I want to run a KENWOOD KAC-9104D and a PPI A404. Is 8 gauge wire from a power block with a 4 gauge input wire sufficiant for these amps?
----------------------------------------------------------------------------------------------edit-
nevermind I just reread the KENWOOD KAC-9104D manual it said 8AWG wire is fine for it. I just answered my own question. A 4 gauge input to 2 8 gauge outputs is what I am getting.
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
571
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
665
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
925
DeathGrind
DeathGrind
Georgetown, CA
DeathGrind
Decebal
    Jun 10, 2024
