Need some advice on box design for my Fi Q 12.
  • 1
gamehawk55
Hey guys,
Been racking my brain over this for weeks and need some professional feedback on the new design I'm thinking of for my 12" Fi Q. The first pic is the box it's in now, and the 2nd one is the design I'm thinking of building. But I need to know approx how this box would sound? Do I have too much port area per foot? Someone told me that 15-16sq inchs of port per foot was too much and the sound would no longer be tight. But I can't seem to get any less port area per foot while still keeping the correct amount of port area (cross sectional), box volume (2.5cuft) and tuning (32hz) correct.
According to a port area calculator I've referred to, my sub needs around 50sq inches of port area to be the most efficient and eliminate port noise.
The box it's in now is "ok". It gets decently loud and hits fairly tight and clean. But I feel for the power I'm running into this sub (2200W RMS), it should be a bit louder and hit me alot harder than it does. Also anything below 35hz really starts to suffer in the current box (due to small port I'm assuming).
Anyways. Hopefully someone can chime in on what they think I might stand to gain/lose with the new box design and what might make it more "perfect".
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
366
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
481
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
826
gamehawk55
gamehawk55
Victoria BC, Canada
gamehawk55
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
