Need some advice on Mojo sub
  • 1
BoostedGenny
Alright I have a 15 inch Memphis Mojo M6 and a srx.1000 watt Memphis amp. The Box is a Memphis single 15 ported enclosure just under 4 cubic feet of air space. Hooked everything up just like I have the other 500 times I've installed a system and this is the worst sounding subwoofer yet. The bass is not very loud, there is barely any "bump" or deep bass at all. All the equipment was checked and in good running condition but I haved 10 inch Memphis PR subs that sounded better hit harder and had more bass. I'm running 2/0 wire with sanded ground areas and a complete Memphis wiring kit. I also have a Memphis 500 amp pushing the door speakers and jvc Touch Screen head unit. Any thoughts or advice?
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
400
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
523
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
848
BoostedGenny
BoostedGenny
Sparta, Tn
BoostedGenny
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
