Need some advice on my Diamond Audio System
  • 2
ranger4416
I have two Diamond M6 10 D4's and a Diamond D5 1200.1 Amp.....Im not exactly sure how to run the speakers wires from the amp to the subs. I was thinking that wiring each seperate sub in parrell and then wiring them both into parrell to the amp would be the best way...but i was told thats not the best way, and I'm just wondering what would be the best?
if they're in one box, just daisychain all the (+) together and run them to your amp's (+) terminal, same with the (-) to the amp's (-) terminal
558
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
657
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
920
ranger4416
ranger4416
St. Louis
acold7dusta
