Need Some Advice on my Setup
first, learn to set your amp gain right. heres how. the test tones are at the very bottom
if you dont get that right, everything else dont matter
Also my budget for everything subs a new amp and battery is 1000-1300 probably
You have a small alternator with an aggressive regulator. Ditch the aftermarket battery and use that money towards a performance alternator.
You might even be able to keep your amp, it's going to get alot louder just by switching alternators (I wouldn't be surprised if your actually creating less than 500 watts right now with your stock alternator).
Your amp (Polk D1000.1) has a 120amp fuse and is rated for 1200RMS, with good electrical it should get very loud with 2x12s
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
359
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
474
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
822
nictowey
CarAudio.com Newbie
nictowey
New Hampshire
mastershake575
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
