Need some ideas for 2 15"L7
  • 2
What kind of vehicle ? How much space are you going to sacrifice for the enclosure ? What kind of amp ? And last but not least what kind of music do you listen to, what kind of sound are you after ? Let me know and we'll see what we can do //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I own a 2002 chevy suburban. Im debatin whether to take out the third row of seats. IM also debatin the amp. it would be nice if u give me a suggestion on that too. i listen to rap rock alternative,etc....(everything except country)
Thanks
Allrighty, well You could put alot of power to those subs. At least a 1000w each. There are several amps that would be ideal. The directed 1100d, phoenix gold has a tantrum 1000d I do believe, The fosgate bd1000.1, The kicker zr1000 would be a good choice if you can find one. There are alot out there. What kind of money are you looking to spend ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I would be willing to spend up to 600 but if i can help id want a go a bit lower
Should i be gettin a mono amp or a 2 channel amp...whats better and what would be the difference when all is said and done...thanx
Originally posted by gdatw019 I would be willing to spend up to 600 but if i can help id want a go a bit lower
The difference is you could possibly use a 2 chanel amp for something else besides subs later on down the road. A mono amp is more than likely going to be a class D nowadays. And it's meant for subs only. I would get a Class D mono amp. They are usually way more efficient than A/B amps.
As for the box. A 6cuft common chamber slot ported tuned to 35hz would fit the bill pretty d@mn well //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I use 3/4" MDF for all boxes. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
146
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
109
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
455
gdatw019
gdatw019
fayetteville, nc
ramos
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
