Next Phase
  • 4
tjmackay
Appreciate the advice received so far to avoid sticking with the stock head unit and using converters to add a subwoofer. Didn't receive any recommendations for alternative equipment, so I went with a Pioneer AVH-X5500BHS, a JL Audio HD750/1 (750 Watt Monoblock subwoofer amplifier), and 2 12 inch Alpine Type "R"'s in a ported "Fox Acoustics" box. Working on the install now and when complete, will be looking to upgrade the remaining speakers and adding an amp to power them. Not sure what would be the best option for replacements or what will fit but again, they are going in a 2009 Dodge Ram 1500 Quad Cab. Thanks again for the help!
I can show you some options for speakers that sound great and aren't the same as everyone else is using. The newer Dodge Ram has 6x9s in the front doors and 3.5" speakers in the dash.
From what I can see, that cable will not work at all, as the A&K only has balanced and unbalanced analog outputs. No digital available. No...
932
Too little power won't smoke a sub...a clipped to hell signal from not setting the gain right can though...
27
1k is iabout the upper end running off stock electrical...and if you don't have the available power for your amp then it really won't hit rated...
12
I know i know another one of these dang threads. I sold my 2 12" xv3 sundowns, they hit good and plenty loud but not enough spl for me. Im going...
Fi 4.12's. Any thoughts? SEMA Showdown this weekend. This is a daily driver. 180+.
tjmackay
tjmackay
Glendale, AZ
trumpet
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
