Next sub build options
  • 1
scparrish
texas
I have been going back and forth on my options going forward and I am just not sure which build to go with. Let's assume that all setups will get the necessary power. This will be in a crew cab f250.
- center console build for 1 SW9152. Will absolutely have to be sealed and even then the console is going to be big.
- center console build for 2 ssa gcons 10s ported, wish the icon was still made in a 10. Should blend well with the interior and not impact leg room in the back.
- behind the rear seat enclosure. Looking at 4 ssa demon 10s or psi baseline 10s sealed. Will never be seen and have no real interior impact.
I do already have a sw9152 sitting around but I am not sure if I want to spend the time required to make it fit. Thanks ahead of time for any input.
Changed my mind about a couple of options. There just isn't a lot of information out there about some of these subs.
From what I can see, that cable will not work at all, as the A&K only has balanced and unbalanced analog outputs. No digital available. No...
953
Too little power won't smoke a sub...a clipped to hell signal from not setting the gain right can though...
27
1k is iabout the upper end running off stock electrical...and if you don't have the available power for your amp then it really won't hit rated...
12
I know i know another one of these dang threads. I sold my 2 12" xv3 sundowns, they hit good and plenty loud but not enough spl for me. Im going...
Fi 4.12's. Any thoughts? SEMA Showdown this weekend. This is a daily driver. 180+.
scparrish
scparrish
texas
scparrish
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
