No sound from rear speakers
  • 2
ukrkoz
wa
Hi
Pioneer MVH-S600BS
Have it connected to Mercury Grand Marquis via Metra Ford harness.
All wires connected properly. Double checked.
Stereo works fine, I had it turned on.
Sound is pretty decent too.
There is NO sound coming from both rear speakers. None. I can't also find any fader adjustment in the head unit itself. It has FRONT in Audio settings, Has Position, but not a word about fader.
It appears rear speakers are simply disabled, or something.
I'll run it with temporary install, in case I need to pull it out. At least front works.
Any ideas?
Try reading the color code on the wiring harness and radio installed and check to make sure installed/wired correctly again.If installed by diagram, try hitting the Re-set Button for like 5-10 seconds on the radio and place your settings back in to see if that may be the culprit
It was not that.
During initial set up I accidentally put unit into Framework mode. What made it a 2 channel rear sub unit. I had to reset it and make sure I have now choice of Standard, instead of framework and that changed everything. Its all good.
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
Before you remove the amp, swap the front RCAs with the rear ones on the amp and repeat the test. Many guys here use the Pioneer amps and love...
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
555
ukrkoz
ukrkoz
wa
ukrkoz
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
