Noob didn't quite get it in the 101
With aero ported enclosures why do you want to have the port on the side vice front facing the same as the woofer? Someone told me that it had to be side facing
Sent from my SAMSUNG-SM-G930A using Tapatalk
If you where doing under the seat in a crew cab that is...is it true
Subs/ port up... sub up/port back... sub front/port side...sub back/port side...sub/port front... sub/port back... lotsa configurations... it's all vehicle/ install/goal dependent... experience counts when deciding on one.
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
The link is from JL audio. It’s a how to set amp levels. The process of setting levels is the same for whatever amp.
AK_stealth
AK_stealth
Virginia
shredder2
    May 16, 2024
    May 16, 2024
