Noob needs help!
I've never upgraded my factory car audio in my life. I bought a 2013 Jeep Wrangler and I love it! The only problem is that when I'm on the highway with the top down (which is often) I want to crank the stereo up so I can hear it. I am worried that I'm going to blow the factory speakers if I crank it up too far. I never go above 75% on the volume for fear of destroying the speakers. But 75% on that system is not enough to hear clearly and get the volume I'm looking for.
I think I'd like to upgrade to speakers that can handle louder volumes and maybe put a small amp in there to give the speakers clarity and a slight amount of thump. But like I said...I have no clue what I'm doing.
Does anyone have any thoughts on how to proceed? Do I need an amp? Do I just need better speakers? I'd prefer not to put a subwoofer in. I don't like a crazy amount of bass, but I do like a slight amount of thump. Clarity is the most important thing to me.
OK - I'm rambling. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Any guidance would be appreciated!
Thanks Fish!
I plan to keep the factory head unit. I don't know much about it. It has bluetooth and satellite radio which I like so I don't want to change it out. If you recommend an amp, which one do you recommend for the speakers you suggested? Can you get quality stuff at a Best Buy? I would need installation if I get an amp so it might be easy just to go there. Thoughts?
thanks fish!
I plan to keep the factory head unit. I don't know much about it. It has bluetooth and satellite radio which i like so i don't want to change it out. If you recommend an amp, which one do you recommend for the speakers you suggested? Can you get quality stuff at a best buy? I would need installation if i get an amp so it might be easy just to go there. Thoughts?
do not go to best buy!!!!!!!
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
Honestly I'd run an audio control DSP or a helix DA helix DSP but if you want to run a app with the DSP that's fine too it's fine too but the LC8...
987
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
Live Wire FL
Live Wire FL
United States
fish1234
    May 31, 2024
    May 24, 2024
