Noob needs help!
  • 3
I've never upgraded my factory car audio in my life. I bought a 2013 Jeep Wrangler and I love it! The only problem is that when I'm on the highway with the top down (which is often) I want to crank the stereo up so I can hear it. I am worried that I'm going to blow the factory speakers if I crank it up too far. I never go above 75% on the volume for fear of destroying the speakers. But 75% on that system is not enough to hear clearly and get the volume I'm looking for.
I think I'd like to upgrade to speakers that can handle louder volumes and maybe put a small amp in there to give the speakers clarity and a slight amount of thump. But like I said...I have no clue what I'm doing.
Does anyone have any thoughts on how to proceed? Do I need an amp? Do I just need better speakers? I'd prefer not to put a subwoofer in. I don't like a crazy amount of bass, but I do like a slight amount of thump. Clarity is the most important thing to me.
OK - I'm rambling. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Any guidance would be appreciated!
Thanks Fish!
I plan to keep the factory head unit. I don't know much about it. It has bluetooth and satellite radio which I like so I don't want to change it out. If you recommend an amp, which one do you recommend for the speakers you suggested? Can you get quality stuff at a Best Buy? I would need installation if I get an amp so it might be easy just to go there. Thoughts?
thanks fish!
I plan to keep the factory head unit. I don't know much about it. It has bluetooth and satellite radio which i like so i don't want to change it out. If you recommend an amp, which one do you recommend for the speakers you suggested? Can you get quality stuff at a best buy? I would need installation if i get an amp so it might be easy just to go there. Thoughts?
do not go to best buy!!!!!!!
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
3K
Honestly I'd run an audio control DSP or a helix DA helix DSP but if you want to run a app with the DSP that's fine too it's fine too but the LC8...
971
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
5
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
8
Live Wire FL
Live Wire FL
United States
fish1234
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
