Nothing wrong with a pair of Fast and Furious
Rodek
41
Alabama
I fired up my old pair of Lightning Audio FF150.2 amps today. 50x2 or 150 x 1 bridged at 4 ohms.
They're actually clean sounding and pretty stout. I'd put them on par with the Rockford Prime R150x2 class AB amps. They're rated the same power output wise and I've compared them side by side. The Fast and Furious theme is a bit flashy for me but they're great conversation pieces.
I had an old Lightning Audio 5 channel amp, wasn't too bad, nothing special. May have had some Lightning Audio wire that did the job as well at some point.
Their Storm subs looked pretty sweet.
Random photo I just looked up.
If you have a spot to place them.. Id run them. Open them up and bench test them make sure caps are good. Id prob leave the cover on while putting power on them on the bench..LOL.. But.. Id run them. Get some more use out of them
Yeah, I plan to run them in my workshop. I haven't gone through them or anything but they startup and run just fine. I don't see any strange spike on my power supply and there are no noises either. I agree. I'm going to get some more use out of them. No use in letting them sit.
Yeah, these are listed as 3ohms nominal and that is why you see the 2.7ohm rating (where they can drop to). There are a number of things wrong...
4
881
When I was delivering pizza the companies had to raise employees wages and in response they hired twice as many employees and cut everyone's...
14
59
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
Antenna unplugged, noise reduced markedly but not gone. Plugged in again and ignition switched off, noise gone completely so antenna not the only...
10
Rodek
Rodek
Alabama
Rodek
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
