Ohm Help
  • 4
bassrock3r
Hey guys I have a subwoofer question. Question about OHM.
I'm buying this amp, Polk Audio Class-D amplifier D5000.5, and I want to know if I should get a 4 Ohm or a 2 Ohm subwoofer.
This is the name of the speaker. RE Audio SRX10D4 or RE Audio SRX10D2
I also have 4 speakers.
Thanks.
Also can someone please explain to me what the difference is.
Dual 2 ohm sub >>> can be wired in series to have a final load of 4 ohms or wired in parallel to get a final load of 1 ohm
Dual 4 ohm sub >>> can be wired in series to have a final load of 8 ohms or wired in parallel to get a final load of 2 ohms
Now from looking at the specs on your amp for the sub channel and the sub, either sub will work, I would buy the SRX10D4 and wire it in parallel for a 2 ohm final load, this would allow me to add another sub later if needed.
Thanks.
What 4 speaker do you have?
I can only fit 1 sub into the car. Will it affect the system if I buy the four but hook it up as a 2 ohm?
Infinity Reference 6032cf ii speakers
The 4 Infinity Reference 6032cf will work on the other 4 ch on the amp, one on each channel and wire it normally because it's already 2 ohm load each.
And yes the 1 sub will work fine on the sub channel, and seen that you will only have one sub, then get the dual 2 ohm (RE Audio SRX10D2).
Just curious, what's your budget for the sub? maybe we can suggest something better.
Well the amp is $300. And I'm looking to buy a sub $100
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
It also lowers the amps efficiency and raises the current draw.
714
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
513
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
bassrock3r
bassrock3r
Yonkers, NY
audiobaun
