OK to add two devices to existing fuse tap?
  • 1
iSarge4
First, Ford F-150 Fuse #23 (10A) Details:
  • Power driven rear glass switch. [Not Implemented]
  • Inverter.
  • Driver side window.
  • Moonroof. [Not Implemented]
  • Vista roof. [Not Implemented]
I currently have a Dashcam wired into a fuse tap to fuse #23 10A in my interior truck fuse box. Can devices #2 and #3 be added to fuse tap (+) by means of two "T-Tap Connectors"?
  1. Blackvue DR750S-2CH (Dash Cam) (already on fuse tap installed on fuse #23)
  2. ESCORT MAX 360c (Radar Detector) (T-Tap into fuse tap #23)
  3. Quick Charge 3.0 Dual USB Truck Charger Socket (T-Tap into fuse tap #23). This will power an AT&T Netgear Nighthawk LTE Mobile Hotspot Router through the USB port.
The following information, I do not know if it is helpful to you in making your recommendation. I thought I would include the info just in case it is needed.
Device Information:
#1: Blackvue DR750S-2CH Dashcam
-DC 12V - 24V (DC Plug (-)--C--(+)
-(03.5 x 01.35), MAX 1A/12V)
#2: ESCORT MAX 360c (Radar Detector): 2A
#3: USB Hub:
Input Voltage: DC 12V-24V
Output Voltage: DC 3.6-6.5V/3A, 6.5V-9V/2A, 9V-12V/1.5A
Portiforium Dimension: 1.13 inches Max Output: 36W(18W each)
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
  • Poll
That strikes me as overboard. We'll probably survive if a thread or two every week comes back from the dead.
18
3K
I took a quick look at the manual for the Jensen. It only says that the usb is compatible with memory sticks and iPhone and iPod. It makes no...
iSarge4
iSarge4
Nebraska
iSarge4
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
