Pa system troubles
mc121
la
I take my truck to the desert an awful lot and i thought that it would be nice to install a cb,pa combo. right now i bought a used cb radio for 30 bucks that is powered from the cig lighter, and i had an old cone speaker lying around which is like a small megaphone. The whole setup works, but isnt loud at all. what do i need?
An amplifier for the speaker. Hooking the speaker straight to the cb isnt going to power the speaker enough. If this will work, get a cheap amp from autozone that can run off of a cig lighter or w/e and get one of those 1/4th to rca cables, hook that up to the cb and the input on the amp, then hook the speaker to the output on the amp. I dont know if that would work but I would imagine it would???
alright thanks alot, ill give that a try. believe it or not but i hooked it up to my 400 watt amp in my car and it was quite loud.
http://img.photobucket.com/albums/v207/mc121/pa.jpg
check this out, possible?
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
318
668
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
16
mc121
mc121
la
mc121
