STIBungy
Alpine MRV-F340 Amp
Alpine MRD-M1000 Amp
Both amps are in excellent condition. Removed from my Honda Element years ago and sat in the garage waiting for a new car. Still no new car. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Here are specs on the MRV-F340
55 watts RMS x 4 at 4 ohms
65 watts RMS x 4 at 2 ohms
130 watts RMS x 2 in bridged mode
2-, 3-, or 4-channel output
Tri-way capable (Tri-Way crossover required)
requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
Bass Engine® features:
variable 30-400 Hz high-pass/low-pass crossovers, 12 dB/octave
rear channels have a subsonic filter at 15 Hz
MOSFET power supply
STAR Topology (minimizes internal noise and prevents ground interference)
speaker- and preamp-level inputs
preamp outputs
oversized power and ground connections
gold-plated screw terminals
top mounted controls with cover
detachable front cover
blue power LED
10-3/8"W x 2-1/2"H x 12-3/8"D
Specs on MRD-M1000
500 watts RMS x 1 at 4 ohms
1000 watts RMS x 1 at 2 ohms
MOSFET power supply and output stage
STAR Topology for cleaner sound
low-pass digital crossover, 30-200 Hz, 24 dB/octave
variable subsonic filter (15-50 Hz in 5 Hz steps)
parametric EQ variable from 30-160 Hz, ±12 dB
Bass Compensator enhances low-end definition (3 settings)
top-mounted digital control center with cover
time correction 0-10 milliseconds in 0.1ms steps
phase adjustment 0-180°
turn-on delay
digital readout
blue power LED
preamp inputs and outputs
outboard fuse holder with 80-amp fuse
requires 4-gauge power/ground leads and an 80-amp fuse — wiring and hardware not included with amplifier
extra-large gold-plated terminals
21-5/8"W x 2-11/16"H x 10"D (11-3/8"D with terminal cover)
MRV-F340 - $175 shipped
MRD-M1000 - $350 shipped
$475 shipped for both.
Within the Continental US
Alpine MRV-F340 Amp
MOSFET power supply
preamp outputs
blue power LED
Specs on MRD-M1000
turn-on delay
digital readout
blue power LED
