Pioneer removeable face...
When I reference design, I mean in how the face itself is fitted onto the left and right pins and snapped into place. Not the actual knob and switch layout on the face itself.
TIA
To pull the face off, the face can be set to automatically lower when the car is turned off. There's a button that you press when you pull it. To replace the face, just push it on. There's no side that goes first. Just line it up and push. Very easy.
So is it accurate that both the 800PRS and the 700BT faces install/dismount the same?
Honestly, I'm not sure how the 700BT works. I do not believe the 700BT is motorized. If this is the case, they are not the same. The 800PRS has a motorized faceplate. There is a setting in the system menu for the 800PRS that automatically lowers the faceplate when there is no more 12V signal on the ignition wire. This gives you access to the release button to remove the faceplate. To replace the faceplate, just put it on. Neither side goes first. All that needs to be done is for you to line it up and press. There's nothing special to it. I believe that's really all you have to do with any of the Pioneer units to put the face back on.
Ahh, I see now...I had the 700BT for a few days and it did not have a motorized faceplate. So they are different.
Thanks
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
345
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
764
mlo
mlo
USA
ejschultz
    May 18, 2024
    May 16, 2024
