Playing one source on multiple stereos at the same time? (FM transmitter?)
  • 3
mcsoul
such is life
4,716
dfw
I want to be able to play one source (say a dvd ripped with mp3's or an ipod) on all the stereos in the house at the same time. All the FM transmitters I see are for the car and likely have a limited range, and possibly a limited frequency range too. A slingbox may do it, but it seems a little expensive and feature rich for what I want to do. Basically, I want to press play in one room and all the stereos in the house will play that song at once (in unison).
Any ideas?
Are they all just standard cd player/radio and ht receivers?
I've streamed music to multiple computers, but I'm sure there's some sort of wifi-based streaming unit if you plan on spending money.
I thought Slingbox was more for broadcasting through broadband to view away from your home?
There are also probably bluetooth options, but I'm not sure the quality would be. I'd stay away from fm transmitters though. Those things are trash.
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Hello, I already posted in general but wanted to also post in here. I recently installed a set of used JL audio shallow depth 12W 1v3-4 inside an...
Makes sense. You may be right on the gain; 2 subs on 300 watts seems anemic.
46
5K
mcsoul
such is life
mcsoul
dfw
JimJ
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
