Only tweeters playing sound while making a phone call (MVH-S520BT)
  • 2
edikecske
CarAudio.com Newbie
Dorog
Hi! I'm struggling with this issue that if I'm making a phone call via my head unit (Pioneer MVH-S520BT), sound is only coming from the tweeters but the door speakers. I have a full active system installed, which means I have the tweeters connected to Front RCA output and front door speakers connected to Rear RCA output (and my subwoofer to SW output).
I already figured out that the problem is probably because the head unit only sends signal to the Front RCA output if there is a phone call. It was working fine before when only Front RCA output was connected to my 4 channel amp with an RCA splitter.
Any suggestions, what can I do for solving this? It is really hard to understand speaking like this.
Thanks in advance!
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I installed my 3 way active setup it didn’t work anymore.
🤣 good catch got me on that one. Around 120 hz is when they kick in. all that info is at the beginning of the thread. Sony XS-162ES’ are what I’m...
29
3K
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
8K
edikecske
CarAudio.com Newbie
edikecske
Dorog
SlugButter
vlusardi
    Apr 27, 2024
winkychevelle
    Apr 27, 2024
Latest topics
