Please Explaine Standing wave to me
  • 6
Wragold
So I got a new car, a Scion Tc, now Im planing out a box to put my system in (I think its in my Sig). Ive measured from the backglass of the hatch to the front windshield. 9.5' or 113". Now should I trying to match my box tuning to work with the vehicle or go from the recommended speaker specifications?
I don't know if I'm doing my math wrong, but when I match the port tuning to the car I end up with a port of like 60hz. 1130/60=18.83/2=9.4 Or am I just doing it all wrong?
I kid, I kid. Are your goals SPL or music? If music you do not want to tune up there. Remember that something as small as distance/orientation in regard to your back wall are going to completely change 1/4 wave mechanics and net you gains/losses in output and range.
You are better off to build the box with 1)The drivers and power you have on tap and 2) Your goals 3) Orientation/Fit constraints in mind. Then work on placement.
lol i get it standing wave.
This is my daily driver, so yes its going to be playing music. What happens at 1/4 wave? I was solving for 1/2 wave.
you can see that Im working with limited room. I think the Vas for the sub was calling for 1.93x2 so total 3.86' cubed. I think I have some plans on paper that would get me close to 3.8'. Im going to have to glass the inside to mold over some bumps on the floor. Now I was down to the port. In the sub specs it shows the box being tuned to 33hz. So are you saying just build my box with the tuning I want and hope there's not cancellation?
You have a hatch, there shouldn't be cancellation. Don't port back and end up less than the port width from the back hatch. I don't recall whether port up or port back is better in a hatch, someone else can chime in on that. You should have no cancellation issues however. Also, 33hz would be wonderful for a music vehicle.
I was going port up in between the subs. That way the bass is pumping into the cabin area. If this ends up working then the factory carpet pull over will still be able to hide the subs.
I have tried sub/port up and sub/port back in my hatch and sub/port back is louder. I do like to look of sub up, but I will switch back. I want to try two tens up and port back.
680
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
589
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
Wragold
Wragold
Charlotte, NC
macsdad
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
