Please help in choosing which subwoofer to go with...
small ported enclosure tuned low, but whoever builds the box will calculate it exactly
• Le: 4.5 mH
• Impedance: 2 ohms per coil x 2
• Re: 3.94 ohms
• Frequency range: 15 - 150 Hz
• Fs: 23.6 Hz
• SPL: 86.9 dB
• Vas: 4.33 cu. ft.
• Qms: 5.00
• Qes: 0.49
• Qts: 0.45
• Xmax: 29.4
using the subs q numbers etc
sorry getting late im about to head to bed lol. u already got my vote but both surreal and rabbit are numbe rone on here. may also want to contact vitveet on here also
the tc sound sis the way to go
TC Sounds Inc.
thilo designed millions of subs back in the day, just search for tc9+ famous and well sort after motor. the most amazing subs u can ever hear. that axis is beautifu and gets crazy loud
Thilo didn't design shit brah. And if I remember correctly you've had your head up his ass for a couple of years now.
ok man, please stop trolling, you dont even know. I have never been told as a tc sounds fanboy lol. So get your head out your ***. I am a big cadence fan u idiot
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
951
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
ATN2DETAILING
ATN2DETAILING
BURBANK
mclerico83
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
