port placement?
  • 3
What kind of vehicle is it going in? That's not going to be enough port... It's better to do fewer, larger diameter ports too. A single 8" flare would do much better.
Follow the basic rule of thumb regardless of what WinISD says. 12-16 square inches of port per cubic foot of box volume.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
726
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
900
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
879
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
Kadori
Kadori
Des moines, Iowa
Kadori
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
