port placement?
What kind of vehicle is it going in? That's not going to be enough port... It's better to do fewer, larger diameter ports too. A single 8" flare would do much better.
Follow the basic rule of thumb regardless of what WinISD says. 12-16 square inches of port per cubic foot of box volume.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
819
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
973
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
Kadori
Kadori
Des moines, Iowa
Kadori
