Post Your Box Specs Here:
Sub(s) w/ RMS: 2x 12" Lethal Injections, 500W RMS
Amp w/ RMS: Elemental Designs, 1200W@ 1 Ohm
Internal D x W X H: 11.25x19.5x14.5 (x2)
Wood w/ Thickness: 3/4 mdf
Chambers: 2
ft. ^3 per chamber (w/out displacements): about 1.85 ft^3
ft. ^3 per chamber w/displacements : 1.70-1.75 ft^3
Tuning Frequency: NA
Port H and W/diameter:NA
Port length: NA
Port extension:NA
Bracing: Chamber Seperation
Pics:
my crappy carpet job
i began to make this sealed box to maximize space in my trunk which it did, but when i got done i realized that i could have made it a little bit smaller. What do you guys think about 12" LI's in 1.75 cubes each sealed (recommended 1-1.75) ??? thats not to big is it ?? i was going to try it out when i get my subs in and maybe mess around with a smaller box later if i dont like it, but i hope it will be fine.
you can always throw some extra wood on the inside to lower the volume.(ttt for a helpful topic)
Here's the specs on my latest box.. It's a labrynth because the depth of the box needed to be 12.5" or less, and the sub wouldn't fit with 3.75 inches of port behind it.
Sub Type: 1 Orion H2 15.2
Box Type: Vented Labrynth (3/4" MDF Material)
External Box Dimensions: 17.5" x 43.5" x 12.5"
Internal Box Dimensions: 16" x 42" x 11"
Total Internal Volume: 7,392 in^3 (4.27 ft^3)
Total Port Volume: 2,605.44 (1.507 ft^3)
Sub Displacement: 829.44 in^3 (0.48 ft^3)
Useable Volume: 4,786.56 in^3 (2.29 ft^3)
Tuning Frequency: 33Hz
Port Mouth (Av): 16" x 3"
Port Length (Lv): 47"
Sub(s) w/ RMS: 3x jl audio 10w3s
Amp w/ RMS: soundstream 10.0 (800-900 watts)
External L x W X H: (5.5" x 8.5") x 56.5" x 16"
Wood w/ Thickness: .75
Chambers: 1
ft. ^3 per chamber (w/out displacements): i forgot
ft. ^3 per chamber w/displacements (Vb): 2.06cuft
Tuning Frequency: 33.9
Port H and W/diameter: 8" x 3"
Port length: 21.75"
Port extension: n/a
Bracing: none
Pic:
nowayhoser-newported1.jpg%20
it is too small. according to the owners manual the dual2-ohm should have 1cuft and 13" of port each. i disigned the box for two of the subs cuz of space restrictions...poly-filled...stuck in a third.
the port comes straight out the side opposite the speakers. i didn't want to deal with the ending the port on a sloped face.
genaric 3.2 cube @ 30hz box. will be about 3 cubes after sub displacement. so between 29~31hz depending on sub size //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
the orange is a 4x8 sheet of MDF, the black lines are the physical cut lines for the saw, and their dimensions and names are listed //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
hope that helps somone in this world.
This $100 over your budget but it checks every other box https://stereointegrity.com/product/bm-11/
10
Yes. Ring terminals will work great. crimp them pretty good. You can hit with solder to make a secure solid connection, and then Heat shrink over...
489
Yes, Winky was triggered and butt hurt enough to start **** when I wasn't even talking to him.
9
Looking for an inexpensive double din head unit that has the following: Front/Rear/Sub outputs XM Ready Just want some ideas
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
bcarpenterfhl
Kiss Me I'm Shitfaced
bcarpenterfhl
San Francisco/Hillsborough, CA
bcarpenterfhl
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
