Post Your Box Specs Here:
I'm finally building my first ported box and it's gonna be a big'un.
5.499^3 including port. I just want someone to check my design before I start cutting.
My my, how this design changed. That port I designed was TINY!
when i designed you that box with 0.5 mdf and a 2 inch diamter port, i used bbp6's driver database to find out that sub's displacement and it was tiny. i can double check if you want. just post the model number and company of the subs.
Sub(s) w/ RMS: DD W6.5/150 each
Amp w/ RMS:Sony Xplod something or other/ Maby 350 if in lucky
External L x W X H:17x15x13
Wood w/ Thickness: MDF-3/4"
Chambers:1
ft. ^3 per chamber (w/out displacements):1.2 ?
ft. ^3 per chamber w/displacements (Vb):i dunno
Tuning Frequency: i think 38
Port H and W/diameter:8x1
Port length:10"
Port extension:n/a
Bracing:n/a
Pic: None for you, needs carpet first
Dimensions i just did for a single Kicker L7 (15 inch):
here you go. someone might want to verify this. but i think it's right. got it tuned to 33 Hz.
box dimensions, dont mind the "port may not fit" message. its a flaw of the program.
port dimensions
the volume displacements if anyone feels like verifying my work
what program is this that you used and where can i get it ???
This $100 over your budget but it checks every other box https://stereointegrity.com/product/bm-11/
10
Yes. Ring terminals will work great. crimp them pretty good. You can hit with solder to make a secure solid connection, and then Heat shrink over...
488
Yes, Winky was triggered and butt hurt enough to start **** when I wasn't even talking to him.
9
Looking for an inexpensive double din head unit that has the following: Front/Rear/Sub outputs XM Ready Just want some ideas
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
bcarpenterfhl
Kiss Me I'm Shitfaced
bcarpenterfhl
San Francisco/Hillsborough, CA
bcarpenterfhl
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
