power draw???
  • 3
assuming you're comparing 2500 to 2500 and running each amp at its optimal ohm load then no. Kicker amps do their power at 2 ohms in comparison to the sundown at 1 ohm. The kicker will draw less current. The sundown will give u more options though.
I sure did. Nostalgia is what brought me to this website, wondering if it still existed. I can still name some of the people and describe some of...
8
205
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
558
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
415
1loudZ71
1loudZ71
iowa
Falcons
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
