Power of the gods!
  • 5
Spl4200
I have a hifonics mars that will do 2x 150@ 2 ohm, 2x300@ 1ohm, 1x1200 @ 1 ohm or...1x.1200 @.25ohm in P.O.S. mode.. I am looking to see if there is an interest for this beast on here.. if there is ill do a bench test (Worked perfect last time I used it) and take pic.s looking for sundown x 15 or ??? If its a sub looking around 1300rms ...15 or 18
Ps..You will need an external crossover. Have a wonderfull day
[/img]
Theres a small crack in the plastic across the stealth logo hardly can see.. i receved this amp this way. Like i said it works perfect. Will get gut shot tomarrow will sell but more trying to trade if u know this amp u know what its worth.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
588
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
752
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
571
Spl4200
Spl4200
traverse city michigan
VanLan
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
