Power Output
  • 3
Yes if both are wired 2ohm and you have both positives and both negatives run to the amp.
I do not use nor do I tell people to set up an amp with a DMM I know people do it all the time and that’s their business if they want to take a chance on it being wrong.
I use an oscope for seting an amp. I use a DMM and a amp clamp to tell me how many watts I am producing or to match amps in cases where I am using 2 amps and 2 subs.
sqrt (600/1) or 24.5 VAC since that is what the amp sees and thus the voltage needed to make the power you want.
note you may not be able to achieve that with clean output since you may not know what the amp is truly capable of. some ratings are at 12VDC some at 14.4VDC some higher (trickery).
some DMM's don't read true RMS (cheaper ones wont). if your DMM is True RMS it will say so.
you can set your amp gain this way but that doesn't mean the adjustments end here. you still need to use common sense and listen to your subs. when they start making bad sounds, turn it down.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
534
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
725
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
556
SuperSaeYoung
Los Angeles, CA
SuperSaeYoung
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
