Power reqs for Focal 165as3 on a DSP?
  • 1
LOMAX
London
I'm moving my current setup into a cargo van and I want to invest in a DSP as my speaker placement will be much more uneven.
I want to drop in a miniDSP C-DSP 6x8, separate the component drivers and figure out what extra power to get.
I currently have:
Focal 165as3 3-way components
Alpine BBX F1200 (2x130w bridged or 4x50w)
JL Audio 6w3v3 subwoofer
Alpine BBX T600 (1x130w bridged or 2x50w)
I'm hoping I can simply use my current amps to power the 6 channels of the 3-way and buy a small monoblock for the sub but I'm worried things will be very underpowered.
The Focal spec sheets are a bit confusing. There is one for the whole kit, one for the woofer, one for the mid, but nothing for the tweeters. Each states 80w nominal, 160w max but surely the overall power requirements should be more than the individual components?
Can anyone tell me what the individual component power requirements are and whether I need to buy more power for the 3-way or just for the sub?
Thanks
LOMAX
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
551
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
738
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
562
LOMAX
LOMAX
London
LOMAX
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
