Precision Power DSP-88R
  • 2
crxsir121
Brand new sealed in the box DSP-88R dsp unit. Awesome unit for adjusting the sound. Now on eBay:
$180/shipped takes it!!!
Digital signal processors have become popular amongst sound quality enthusiasts recently. Although they generate near audiophile grade sound, they tend to be difficult to program, and down right confusing. To remedy this conundrum, Precision Power introduces DSP-88R, a user friendly DIY DSP that offers the features and performance you need.
Core 32 Bit / 192kHz Digital Signal Processor Powred by Cirrus Logic
Dedicated 8-channel DMA Engine Streams Data Without DSP Intervention
Integrated 105dB Dynamic Range, -98dB THD+N Analog-to-Digital Converter
Integrated 108dB Dynamic Range, -98dB THD+N Digital-to-Analog Converter
Custom User Friendly DSP ComposerTM Graphic User Interface w/ Response Display
30V MAX 4-channel High Level / Speaker Level Input
8V MAX AUX RCA Input Voltage
192khz S/PDIF Optical Input
Optional High Level Input from Hands-Free Bluetooth Module
8 Channel Low-Level RCA Output
Optional Independent Input or Channel Mixing/Summing
Up to +12dB / -18dB Master Input Level
Up to -40dB Independent Channel Level Cut
Up to 16ms Independent Channel Delay, 0.05ms Incriments
Independent Channel 0°/180° Phase Control
Independent Channel High Pass, Low Pass or Bandpass Crossover
Selectable Independent Channel 6dB-48dB/Octave Crossover Slope
Variable Frequency Crossover Setting, 20Hz-20kHz
1/3 Octave/31-Band Graphic Equalizer for Each Channel
+12dB Boost / -18dB Cut for Each Band
Variable Independent Band Q Adjustment, 0.5-9
Dash Mount Remote Control Included for Input, Mode, & Volume
http://www.precisionpower.com/html-v...88R-manual.pdf
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
499
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
713
crxsir121
crxsir121
San Diego, Ca.
dailyrider123
