Precision Power P900.4 145W x 4, 4 available
trumpet
Barry Schanz
Precision Power Phantom P900.4 Class D Full Range 4 Channel Amplifier
Power Ratings:
RMS Power 4 Ohms(14.4V) 145W x 4
RMS Power 2 Ohms(14.4V) 225W x 4
RMS Power 4 Ohms Bridged(14.4V) 450W x 2
RMS Power 4 Ohms(12.0V) 100W x 4
RMS Power 2 Ohms(12.0V) 150W x 4
RMS Power 4 Ohms Bridged(12.0V) 300W x 2
Additional Technical Specifications:
Class D Full Range SMT Circuitry
Double Sided Composite Epoxy PCB
102 dB Signal-to-Noise Ratio
114 Damping Factor
32 dB Stereo Channel Separation
200 mV – 6V Input Sensitivity
Input Impedance 3.3k Ohm
20-4kHz 12 dB High Pass Crossover
50-5kHz 12 dB Low Pass Crossover
Source Input Selector
Three-Way Protection Circuitry
Delayed On/Off Circuit
Tri-Mode Capable
Band-Pass Crossovers
Direct Wire 8ga. Power & Speaker Terminals
0ga Reducer Terminal Included
Dimensions:
6.5″ W x 9.5″ L x 2″ H
NIB
ships free by UPS Ground
Fedex and USPS available upon request
on hand now, no waiting list or "sorry, we don't have this in stock" e-mail after you've already paid for it
I run this amp on my midbasses and mids and it is very efficient, very very low noise floor, tons of power, no turn on pops, and very small.
i purchased one of these before you had them forsale on here and this amp is amazing to say the least! So small, so powerful, and it sounds great!! I would definetly recommend this amplifier to people //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm seeing different widths on this thing from 9.25" to 11" - do you know the actual width? I need to fit this into the stock CD changer location, and I'm concerned about it sticking out too much if it's > 10" wide (not counting wire connections).
Basically, it's going to be mounted in some styrofoam hoops, and I'm worried about the mounting holes going past the edges of the styrofoam block.
I just measured it and it's 10-9/16" long. With a tape measure I'm getting 9-7/8" between hole centers.
1 more sold, 6 available
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
451
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
689
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
