SOLD Precision Power PCX-5800
  • 2
RetroAudioinc
Custom Car Audio Decals
1. Product:
2. Specs:
Advanced Instrumentation Input Stage
TC-X Crossover 12dB/Octave; HP/LP/FULL; 30-4kHz Crossover.
Adaptive PWM Power Supply.
Fully Complimentary Triple Darlington Output Stage.
AP-IV Protection Circuitry.
Forced Air Thermal Management.
QBASS Plus™ Bass Boost.
High Voltage Input Capability with -12dB Attenuation Switch.
Gold Plated RCAInput and Output Connectors.
PowerLock™ Speaker and Power Wire Connectors.
Mixed Mono/Stereo Operation.
Designed and Handcrafted in the USA.
Power Bandwidth 10 Hz - 50 kHz
Total Harmonic Distortion > 0.02 %
S/N Ratio
Input Topology Instrumentation
Input Sensitivity 150mv - 12 Volts RMS
Input Impedance 10k Ohms
Load Impedance (stereo) 2 - 8 Ohms
Load Impedance (bridged) 4 - 8 Ohms
Supply Voltage 11 - 15 Volts
Damping Factor > 500
Slew Rate > 50 V/μS
QBASS™ Up To +12dB @ 40Hz
QBASS PLUS™ Up To +18dB Boost
@ 30, 36, 44, or 60Hz
Crossovers 12dB/Octave
Crossover Frequency 30-4kHz
Idle Current: PCX 5800 2.5 Amps
MODEL 4ohm STEREO 2ohm STEREO 4ohm MONO
PCX 5800 4 X 50 4 X 100 2 X 200
4ohm MONO 2ohm MONO
5/Ch. 1 X 200 1 X 400
* ALL POWER RATINGS SHOWN ARE TESTED @ 12V; 4 ; 20-20kHz
3. Description/Condition:
This thing is minty minty one owner my wife, it's been in her car for years. I am just changing her system out so thought I would offer this up to someone lucky. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif This amp only has alittle mark on the feet and where the power ground plugs go in. Other then that it's minty the top is very minty looks brand new.
I also have ALL PLUGS...
4. Price: :
$650 shipped OBO OR TRADE..
5. Pictures:
AMP GUTS PHOTOS MINE HAS NEVER BEEN OPENED!!!!
Precision Power PCX-5800 - Amp Guts
Any one at a body shop in Orlando I would trade this to fix my civic if it's not fixed after replacing everything on the driver side suspension, a-frame and swaybar. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Hit a curb at 90MPH needs a little frame TLC.. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Yep... 100%... Besides where the little power, speaker plugs go as shown above... See here... Other then that this thing is like new very very little use.. Wife has had her civic since 1999 and put like 10k to 15k miles on it lol. I hate driving little cars so we take my truck most places, plus she drives slow.. haha
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
581
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
750
RetroAudioinc
RetroAudioinc
Indianapolis, IN
RetroAudioinc
