Proper Box dimensions for 2 American Bass XFL 1244s??
  • 2
intendwithin
CarAudio.com Newbie
Hey all! I want to build a box for my two new subs that I just bought. Can anyone recommend dimensions for a box that can get these puppies low low? I am running these subs in parallel to 1ohm with a Skar Audio RP-2000.1D amp. Each sub should be getting its rated 1000watt rms rated power supply. So far I have designed a box with external dimensions of 15hx36wx20d using 3/4 inch material and using a double baffle. I am thinking going aero port by using 2 4" diameter 10" long pipes for the port. I'm hoping that gets it to 32hz tuning. At least that's what the cheesy free online calculators tell me.
Any help would be awesome!
Thanks!
I would do as much as you can afford when you place your new speakers in if you cant do it all now. you can always pull your door panels off later...
420
Someone was telling me I need to have a battery isolator and some kind of DC to DC charger or do I run it directly off the main battery post pos...
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
409
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
755
intendwithin
CarAudio.com Newbie
intendwithin
Kimberly, Idaho
yamomluvsme
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
