Proper Door Sound Deadening and You
A plexiglass cutting recomendation. Plexiglass is designed to score and break, and it's much easier that way, unless you have compound curves to cut in. All you need is a utility knife and a straight edge. It also grinds well to take off edges and round corners.
Does anyone know if the wal mart scosche accumat is asphalt based?
Richard
;edited for clarification;
A plexi cutting tip. It's designed to score and break, much easier that way, unless you have compound curves to cut in. It also grinds well to take off edges.
Richard
Plexiglass cut just fine for me with a jigsaw, I just made sure each side of the glass I was cutting was held down good and didn't flex. And as for the walmart stuff, I know nothing about it, but I wouldn't buy it if I were you, I'm sure it's pretty horrible.
I would do as much as you can afford when you place your new speakers in if you cant do it all now. you can always pull your door panels off later...
478
Someone was telling me I need to have a battery isolator and some kind of DC to DC charger or do I run it directly off the main battery post pos...
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
7
423
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
686
squeak9798
Banned
squeak9798
USA
Gunk
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
