Proper Door Sound Deadening and You
Hmm I just matted over the open spaces in my door to seal them up, I didn't want to spend the time cutting anything out and I had ALOT of unique shapped spaces in my doors. so I jsut stuck a large piece of RAAMAT over them, Bad Idea?
heres my gosh diddly darn door
each door has 3 layers of spectrum (half gallon) mainly on the outer skin, eDead v.1se on the inner skin, deflex pads, plexi covering that one hole, and clay for the mid.
Not a bad idea but its not as stiff as a piece of MDF or plexi would be
x2. if it's a big hole like the one i have, i would put mdf/plexi. i left the small holes covered with mat.
hey those are the pg xenons right? how you like em? where's your tweet mounted. sorry this is off topic, i am in the process of insalling those too. if you guys had limited cash, what areas of your car would you sound deaden first, and with what and how much of it? thanks
Walmart, its where the markers are.
I bet my friends clay has all come off in this heat. I cant wait to see the puddle of clay on teh door sill
The clay looks good, but how long will it last? Looks like it would fall off in no time.
depends on the clay and the climate. i got mine at a arts/crafts store, was kinda expensive, but it doesnt melt in hot weather.
you dont need clay at all
Just make shure that the extremis' are sealed.
Cheap wal mart clay doesnt last in the cali heat.
It literally pooled out of my friends door onto his sill.
Not like it cost me a whole lot, $.97 a pack
Is it necesary to deaden the inside of the outer skin. I deadened the actual door under the skin today, and it was a ***** to do with second skin sludge it took like 3 hours to do both. I have no idea how I would be able to do the inside of the outer skin, how would I see what I covered? And my panel has lots of holes in it, and they aren't just holes, its hard to explain, ill try to get pics tomorrow, but any tips for me?
evan
evan
yea u wanna get the outer skin, very important. u can tell where u've been by the color of the sludge, it was easy to tell with spectrum for me. if the holes are big, cover them with mdf/plexiglass and if it's not too big mat should be fine.
Yea I am definately getting the outside of the outside skin, but I meant the inside of it. I got the inner "skin" i guess you would call it really good. Its hard to explain how the holes are, i'll take a pic tomorrow and post it, my doors holes are nothing like the ones on the original post. I guess i'll have to buy mat to cover some of them and put mdf on the normal holes. I hate to have to buy more deadening after buying 5 gallons of sludge, but oh well, as much as i'll have into this system ill have to.
I would do as much as you can afford when you place your new speakers in if you cant do it all now. you can always pull your door panels off later...
476
Someone was telling me I need to have a battery isolator and some kind of DC to DC charger or do I run it directly off the main battery post pos...
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
411
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
677
squeak9798
Banned
squeak9798
USA
Gunk
    May 31, 2024
    May 24, 2024
