Questions about DD Amps
BahDunkAdunk
Hiya y'all. I need a new 4 channel amp and was looking at the Digital Designs C5c amp. I'm wondering how its only 250 dollars, cause I thought DD products were supposed to be very expensive. Is this a good amp? And are these products still made in America?
I am new here and tried to search this but had no luck so I'd appreciate the help
Amps are from Korea. C5 is an ok amp overall.
Darn, the C5c is only ok? That's disappointing, I thought DD was supposed to have high end stuff. Well what would y'all recommend then for a four channel amp? Looking for around 100 watts rms at 4 ohms and 500 dollars is the highest I could go but cheaper options are definitely appreciated
the dd audio c5 is only an entry level amp. not much is in the case as its not etched and look at the imputs they went nack to the older style you need terminals to do the install . if you are looking for something that is high end you need to step up and they are steep . and i would say if your looking to be at 500 or less i dont think they have anything but the c5 unless you find a dealer that sells less than map price
Also Better n Reverse, does that mean you'd rather have the C5c amp or one of their higher end amps over the Crescendo?
Well what sort of High end are you talking? DD is by no means middle of the road equipment as far as quality and reliability so dont let that sway you from getting it... If you want pure SQ out of an amp though its probably not what your looking for...
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
536
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Thanks for the reply bass addict. I am sure with ya'lls help I'll get it tuned up. Audiobaun has been a huge help. He basically linked everything...
50
6K
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
BahDunkAdunk
BahDunkAdunk
San Diego
