RCA cables
  • 5
sturdy connectors and wiring. In a daily driver they all work about as well as the next.
Dayton audio makes some that I consider better then monster.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
720
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
703
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
610
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
6
763
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
11
909
Memphis2011
Memphis2011
Maryville,TN
murph
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
