Rca connections to amp (one or two sets?)
  • 2
Drifter mike
CarAudio.com Recruit
32
Greece
Hello guys,
I own a Pioneer DEH-S320BT stereo in my car and want to install a sub and amp. I have on mind buying a 4 channel TRF M600.4AB amplifier and connect the sub to channels 1 and 2 bridged and also connect 2 additional speakers on car's shelf (on channel 3 and 4). On the amplifier there are two sets of rca inputs, one set for channel 1 and 2 and one set for channel 3 and 4. Am i supposed to connect two sets of rcas from my stereo to the amp or just one? In a few words what is the appropriate way to do the rca connections? I am a little confused.
I hope the following pictures will give you an idea.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
558
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
542
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
506
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
6
703
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
11
791
Drifter mike
Drifter mike
Greece
KicktheSDbasshead
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
