Rca's Sub
  • 2
If you have a bridged 2 channel amplifier, you want to run a 2 channel RCA cable to your sub amp UNLESS it only has only one RCA input (home audio is like that, most car amps are not though)
Probably 95% of the amps out there take signal from both L/R inputs when bridged. So by using one input you may not get full signal. As for using a Y adapter at the amp, if your HU does not have a mono sub RCA output, you'll only get half signal from the HU. Some HU's have a sub output that can be changed from Mono/Stereo along with crossover etc...
Yep, the subs don't move at all when both RCA cables are plugged in. I updated the firmware this morning. Unfortunately it didn't fix my issue...
33
7K
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
Having to adjusting the sub input sensitivity depending on the music, would be reason enough for me to go with the RCA cables. It does seem odd...
Many moons ago I was heavy into Car Audio Systems(Iasca stuff) but a ton of things have me removed and knowledge forgotten so I need a refresh. I...
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
867
blowsoot
blowsoot
Los Angeles, CA
knukonceptz
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
