Sub wiring via rear speakers vs RCA
  • 2
caraudiogc
CarAudio.com Newbie
Hi Everyone,
I have an active JL Audio sub (ACS112LG-TW1) wired via rear speakers in my VW Tiguan. The original head unit did not have the RCA connectors, therefore, wiring via the rear speakers was the easiest option. This setup seems to have the drawback that it often requires adjusting the sub input sensitivity depending on the music. As the original head unit died a few months back, I replaced it with an aftermarket Android-based unit (Eonon 9) . This unit provides a dedicated RCA output for a sub and also allows adjusting the sub output level via the unit. Is there any other pros and cons of swapping the current wiring from the rear speakers to RCA? Does it have any impact on the sound quality?
Thanks in advance!
Hi Everyone,
Thanks in advance!
Having to adjusting the sub input sensitivity depending on the music, would be reason enough for me to go with the RCA cables. It does seem odd that you had to adjust the input sensitivity regularly. If the signal from the rear speaker was strong, it seems that your amplifier would play all types of music without the need for adjustment. I'm no expert, but that is puzzling. maybe some of our experts can shed some light on this.
A little DAP will do ya, drill, feed & seal, done.
608
two d2 subs can be wired to .5 or 2 or 8 ohms not 1 heres how to wire subs...
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
I'd wire the SVC subs in series for an 8 ohm load. Wire the DVC subs coils in series for a 4 ohm load. Wire the 4 ohm and 8 ohm load in parallel...
4
997
caraudiogc
CarAudio.com Newbie
caraudiogc
Gold Coast, Australia
huberoy123
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
