repurposing 10" sub from infinity baselink
  • 2
aolm
4
NJ
My baselink amp appears to have finally died after 7 years of use. I took apart the case and the 10" sub seems to be fine. I get a 2ohm reading with my multimeter from the sub. I thought I would buy a sealed enclosure and a 300w mono amp and try to bring it back to life. Any thoughts on this from the anyone? I am concerned about the 2ohm speaker being paired with an (inexpensive) 300w sub amp.
https://www.manualslib.com/manual/76936/Infinity-Bass-Link.html
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
488
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
4
343
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
487
aolm
aolm
NJ
bigblank69
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
