repurposing 10" sub from infinity baselink
  • 2
aolm
NJ
My baselink amp appears to have finally died after 7 years of use. I took apart the case and the 10" sub seems to be fine. I get a 2ohm reading with my multimeter from the sub. I thought I would buy a sealed enclosure and a 300w mono amp and try to bring it back to life. Any thoughts on this from the anyone? I am concerned about the 2ohm speaker being paired with an (inexpensive) 300w sub amp.
https://www.manualslib.com/manual/76936/Infinity-Bass-Link.html
Hello, New here thank you. I have a 1999 Jeep Wrangler and just want some sound. I bought a BOSS560RBG head unit because it was marine grade and...
Sensitivity is usually measured 1watt 1 meter. I'd go by that. Higher the better on subs too. Less power to get louder. Every 3 DB gain is like...
126
I've been a fan of the JL shallow mounts, and have actually heard a decent box with some Pioneers but the Focal are pretty darn good. The JL TW's...
240
256
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
273
aolm
aolm
NJ
bigblank69
SlugButter
    May 4, 2024
slater
    May 2, 2024
